Array of clusters and in the cluster is a bar meter, how can I change the color individually?
Array of clusters and in the cluster is a bar meter, how can I change the color of the bar meter individually for each element of the array?  I have just figured out that you can't change properties of one element of the array without all elements changing.  For the scaling I had to make numeric indicators for each tick of the scale so that each bar meter in the clustered array would have individual scales.  I also had to do some math to scale each barmeter to display correct proportions from 0 to 100%.  Now I'm stumped on the color of the bar meter.  Basically, if the value goes over a setpoint, the bar meter needs to turn red.  It has to be in an array to be infinitely scalable.
Matt
(3,592 Views)
You can't do that-
without a little trick.
You could consider laying a custom color box over the bar graph in the cluster you can set the color based on the value of the bar graph or even make a "Pseudo"- bar graph using a series of color boxes stacked to look lie a bar and changing values of the Color boxs from empty to full to red.
Here is an example to demonstrate
(3,589 Views)
Accepted by topic author Mattjk
And yet anothr approach...
right-click the bar >>> Fill Options >>> Fill to maximum.
Color the fill the same color as the background color then make the background color transparent.
Drop a color box BEHIND the bar and size correctly.
It has this weird 3D background with flat bar, but what the hey, its close. If its important a customized color box.
Ben
(3,572 Views)
This is a good idea Ben, Thanks.
(3,555 Views)
