Array of front panel changing size on another computer.
I am having a strange issue here. I am using array indicators on a front panel to convey information to an operator. Everything is the same size and aligned on my system, but when I take it to another system a few of the arrays change size. See pictures. I have tried to set the height of the indicator using a property node, but I can't write to that. All of the arrays are using the same font and font size. Any help would be much appreciated. Thanks.
(3,495 Views)
Accepted by topic author robot_mower_guy
Hi guy,
set the exactly same font for all arrays and labels. I usually use Tahoma 13 (instead of generic "Application Font").
Then set that font in the app INI file using the FONT keys:
FPFont="Tahoma" 13
BDFont="Tahoma" 13
appFont="Tahoma" 13
dialogFont="Tahoma" 13
systemFont="Tahoma" 13
(3,490 Views)
That did it. Thank you.
Now, onto trying to figure out why LV is printing thousands of labels instead of just 2...
(3,466 Views)
Hi guy,
you create a new thread for that different topic, I guess…
(3,446 Views)
Sorry, that was a joke, but I was subtracting 20 from an unsigned int and was underflowing the variable for pages to print.
(3,435 Views)
