Array of numeric sequences
I have a problem creating an array of numeric sequences.
I would obtain an array containing a sequence of numbers repeated n times.
I managed a simple for loop to generate one time the sequence and store it into an array (attached). But I am a newby with labview and I can't understand how to generate the final array of sequences. Ideally, I would also convert the final array into a string (I think I could use something like number-string conversion at the end).
Many thanks for any tips
(2,016 Views)
Hi Principles,
So you want something like 123412341234 (each digit is an element of an array) by first generating 1234 and then repeating this step 3 times?
What about using two FOR loops, one inside the other?
This sounds like a very simple example to have you learn LabVIEW concepts!
I made this using LV2011, with recent LabVIEW versions you should use their improved output tunnel options!
(1,990 Views)
I would use a concatenating tunnel (look it up!). 😄
(1,951 Views)
