Array of strings
This should be an easy question. I am trying to use the "Write to Spreadsheet" VI from Labview 8.0 but I need to modify it to accept arrays of strings rather than arrays of doubles. 8.2 does this automatically, but I am stuck using 8.0. The instructions in the block diagram of the original VI says:
"You can modify a copy of this VI to accept arrays of strings by changing 2D data and 1D data arrays to arrays of strings and setting the format to %s."
I am having a problem changing the data arrays to arrays of strings. I have looked in "properties" for an option and also looked in the "representation".
How do I change the control numeric array to that of strings? Thanks!
(4,099 Views)
Accepted by topic author mechEmike
Right click on the numeric and select 'Replace'. Just browse to the string control on the palette.
(4,098 Views)
I tried that and there is an issue with the "Array Size" function used downstream. I am posting the VI.
(4,081 Views)
You have not done any modifications to that. You need to do the three steps that are listed - replace the 2D, 1D, and format string.
(4,076 Views)
I tried the replacement you suggested but ran into the problem with the array size. I posted the original so that you could try what you suggested. I'll try it again and reply again with the modified VI.
(4,072 Views)
Nevermind. I got it. Thanks!
(4,071 Views)
