Array question
I have a 1X2X2 dimension array and I need to convert it to a 2X2
matrix. The array to matrix thing won't work as the arrays are of the
wrong dimension. How do I equalise them? I tried delete subset array
etc and no luck.
Hardy
(4,331 Views)
hope this helps:
I use an index array just so you know
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,328 Views)
> etc and no luck.
> Hardy
This newsgroup isn't really active.
forums.ni.com is a better place to post these questions.
I presume you want to do this pro grammatically in Labivew. One thing that you could do is just to index into the array, addressing the first indice "1". This will result in a 2x2 double array (matrix).
(4,273 Views)
What does that mean?  This message is on the NI discussion forums.
Link to your message is http://forums.ni.com/t5/forums/replypage/board-id/170/message-id/428494.Smiley Surprised
(4,263 Views)
Whoever this user is, he/she has posted the comment many times, apparently only uses a usenet reader, and is plainly too stupid to realize that messages here are mirrored to comp.lang.labview.
(4,253 Views)
> etc and no luck.
> Hardy
try "reshape array"
(4,195 Views)
Lol!!!!!!!!
(4,171 Views)
