Array related questions
Hi Guys, can anyone explain what does the all the array Vis in the inner case structure represent in the attachment as attached? I am kind of confuse why do we initialize another array when we already have a set of data?
(2,554 Views)
It replaces column 11 of the original array with a new column of all 0s, except that the value is 1 at the minimum index from the for loop above. Since it replaces an entire column of the array, it is necessary to initialize a 1-D array of the correct length (the number of rows).
I may have rows and columns reversed in the above description.
(2,535 Views)
