Array selection start selection end
How is this context menu used on an Array (right click on an array, not the array-item, in a runtime LabVIEW). A blue line or box appears when Select All but not sure what to do with the "Selection Start" or "Selection End" on the Array context menu while the VI is running.
Can I select array item(s) and get them out of a property or on the clip board etc.....
Message 1 of 8
(7,623 Views)
Those options work with array indexes.
Set your array index to the first element you want to copy and then do the "start Selection".
Set the index to one more than the last element you want to select. and do end selection.
Data operations copy data.
If "show Selection" is enabled you will see the selected data.
It will copy to the clipboard and you can paste it into another LV control if you want.
Ben
Message 2 of 8
(7,603 Views)
Got it thanks!
For the record let me add, you need to Use Array Invoke, Export to Clipboard, to paste outside of LabVIEW. Otherwise the control's picture as it appears on the FP is on the clipboard.
Message 3 of 8
(7,552 Views)
Doesn't right click>export also work? That should have the exact same effect as the export invoke node.
Message 4 of 8
(7,530 Views)
I suspect as much.
Just do not try to do that on an array of enums (without saving everything first).
Ben
Message 5 of 8
(7,505 Views)
Ben
Seemed to work fine for me (LV13 and LV17). Trick is the enum needs to be a type def, or everything is fine. This crashes 13 and 17. I assume it's reported?
Message 6 of 8
(7,485 Views)
wiebe@CARYA wrote:
Ben
Yes sir!
Ten minutes after it bit me, I had LV crashing for the AE in Austin. Got a shiny new CAR within hours. I also asked that it be flagged for the LV Champions monthly report.
In my case I was trying to get a handle on the state transitions of a state machine that had been developed by someone else. I was building an array of the type-def'd enums and displaying same on the FP. When attempting to copy the array contents LV crashed. So it made me question why nobody noticed that problem previously.
Take Care,
Ben
Message 7 of 8
(7,474 Views)
Yes, I was looking for the programmatic way not UI way of exporting.  Thx
Message 8 of 8
(7,440 Views)
