Array size of empty array - bug
Let me rephrase ‘expected output’ and ‘unexpected output’ as output 1 and output 2. Apparently both 1x0 and 0x0 arrays are empty arrays, so I assume these arrays to behave exactly same in any given instance. Since 1x0 and 0x0 empty arrays had different behavior i.e. output 1 and output 2 (irrespective of which is right/expected) in the discussed example, I considered it has a bug.
Necessarily, should I consider 0x0 and 1x0 empty arrays as two different instances of empty array and expect it to behave independently?
Message 11 of 13
(1,523 Views)
Yes.
Message 12 of 13
(1,519 Views)
It seems confusing, but i think it's helpful to think of a Nx0 or 0xN array as an Array of Empty, instead of an Empty Array. The Empty Array primitive checks if some dimension is 0, but just like Inf /= Inf sometimes two empty arrays can be different.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 13
(1,503 Views)
