Array sorting by formula node
Hi, everyone, I want to use the formula node to sort one array with small to large value order, e.g 16,2,1,5,3, then the result should be 1,2,3,5,6.
then my program is like this, but I cannot get the corret answer. Please help me. Thank you very much.untitled.JPG
Working...
Message 1 of 9
(7,019 Views)
I hate to break it to you, but you are re-inventing the wheel.
Use the Sort function in the Array palette to achieve what you are trying to do.
Cory K
Message 2 of 9
(7,011 Views)
Hi, the function you shown up is what I know before.
Now I am just trying to practise the formula node, but it can not work, could you help me to work on the formula node? Thank you very much for your reply....
Working...
Message 3 of 9
(7,005 Views)
Yes, I can help you out with your text programming Smiley Mad , let me look over your formula node quickly.
Cory K
Message 4 of 9
(7,001 Views)
It is so kind of you to give me the help....:womanvery-happy:
By the way, I checked the code in Dev-CPP softwar, it works, but here is strange.
Message Edited by McArthur on 06-25-2009 03:19 PM
Working...
Message 5 of 9
(6,993 Views)
I have it like this sometimes my self. Sometimes I need a breakpoint. But then I prefer doing it in Assembly language. Just for fun I toy with a Microchip CPU. For a short time I can feel the joy and rush of taking a chunk of memory and do whatever I like without going through some sort of memory management. Perhaps it reflects my daily situationSmiley Very Happy
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 6 of 9
(6,987 Views)
It is really difficult to get the answer, I am still hung on it.
Working...
Message 7 of 9
(6,978 Views)
Accepted by topic author McArthur
McArthur,
You are probably getting an array of zeros because you are iterating the inner loop one to many times.  Change line 9 to "for(j=0;j<(sizeArr-1);j++)".  This should give you correct numbers.
Having said that, this algorithm is very inefficient (O(n^2)).  I would suggest simply using the native "Sort 1D Array" primitive.
Chris M
Message 8 of 9
(6,975 Views)
Ha, Thank you very much. you solve my stupid error...
But still strange that I can compile and run them in the Dev-CPP.
like:
#include <stdio.h>
#include <stdlib.h>
#define sizeArr 5
int main(int argc, char *argv[])
  int inArr[sizeArr]={6,1,4,5,0};
  int *ii=inArr;
  int i=0;
  int j=0;
  int temp=0;
  for (i=0;i<sizeArr;i++)
   for(j=0;j<sizeArr;j++)
         if (inArr[j]>=inArr[j+1])
              temp=inArr[j+1];
              inArr[j+1]=inArr[j];
              inArr[j]=temp;
  printf("Hello\n");
  for(i=0;i<sizeArr;i++)
     printf("%d\n",inArr[i]);
  system("PAUSE");
  return 0;
What I got is:
Working...
Message 9 of 9
(6,970 Views)
