Array to Spreadsheet String - no end of line
In the attached VI, I was expecting to get an end of line character at the end of each array element.  In the string indicator on the front panel, I get one row instead of three.  What have I done wrong?
Thanks.
(5,774 Views)
You need 2d-array.
So you can use this variant of preparing your data
Or make 2d array directly.
(5,762 Views)
Accepted by topic author AT1
By default, a tab is the delimiter for the spreadsheet string.  Just set that to be the End Of Line constant.
(5,741 Views)
As Suggested by crossrulz you need to feed delimited values to separate your array data, to get values in three rows you need to provide end of line character as a delimited value.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(5,692 Views)
Thanks for everyone's help!
(5,661 Views)
