Array to Write to Spreadsheet
Hi everyone,
i got this problem, 'the type of source is 1-D array of string. The type of sink is 1-D array of double'... How do i resolve this?
Thank you for answering this.
As attached is a snip of the vi i created.
Using Labview version 8 , winsXP
(3,097 Views)
Older versions of LabVIEW don't support arrays of string for "write to spreadsheet file".
You need to explicitely use "array to spreadsheet string", then write the resulting string to a file using e.g. "write text file".
(3,084 Views)
In the string palette is a function called array to spreadsheet string, use that to get a string then a  write to text file function gets it on disk.
Paul
(3,083 Views)
Hi again,
i will do just that, thanks again.
(3,050 Views)
