Array to spreadsheet.
Hi,Guys,
I have a 1D array need to write to spreadsheet,after run I found out the data was in the same of the excel file.
the peoblem is the data is 20,000+, I think put the array in one column is better,right?how?
Cheers,
Nicosg
anico2127@yahoo.com.sg
(3,233 Views)
Hi Nicosg,
On your write to spreadsheet vi there is an input boolean labeled transpose.  This will save your 1D data as a column.
Cheers,
Jim
LV 2020
(3,227 Views)
Hi,lmtis ,
Thanks a lot.
Cheers,
Nicosg
(3,191 Views)
