Array
Oops Ya I knew it is a big mess 😞
Message 11 of 15
(1,582 Views)
Please also attach the two VIs. The snippets don't work right. E.g. where does the boolean property node point at?
Please also remove all orrelevant and dead code so we can focus on the problem.
For example, the following loops do the same thing (and if you need the "+1", use use array subset before the loop).:
Message 12 of 15
(1,561 Views)
I am very new to LabView and did not know where else to post this question. I cannot identify this type of structure (it looks like multiple numeric controls in some sort of array or cluster??) I found this program in the example --> serial --> Simple Serial folder in labview. I am trying to re-create this control myself, so any help would be greatly appreciated.
Thanks in advance,
Mridu
Message 13 of 15
(1,473 Views)
You should have started a new thread since your question is unrelated to this.
It's a cluster. The Context Help would have told you this. Taking some of the free tutorials would have told you the same thing.
Message 14 of 15
(1,460 Views)
Oh my bad, I did not know - very new to the forum
Thank you for your help, that clears a lot
Message 15 of 15
(1,445 Views)
