Array
HI
I have an array of 9984 of  I32  I want to be able to make 78  array's of 128  x I32 can some one please show me how to do this.
Best Regards
David
(4,615 Views)
Can you share more details?
Maybe some code?
I am not sure I understand what you want to do.
(4,594 Views)
hi dpjones,
sounds like you want array reshaping.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(4,585 Views)
Hi  jwscs
Thanks for your help  it worked fine I have one other question regarding the array reshaping after I have reshaped as per your vi what is the best way to select and show one of the rows 1 - 78 on an FFT .
Best regards
David
(4,519 Views)
@DPJones wrote:
Hi  jwscs
Best regards
David
Use the array properties to show the correct row, amount of elements, and which element will be the top left one.
Bill
CLD
(Mid-Level minion.)
(4,517 Views)
Accepted by topic author DPJones
(4,490 Views)
David
(4,475 Views)
