Array
could someone help me how to display 5th ,6th and 7 th elements in an array indicator and also how to sorted random numbers in ascending order using 2nd array indicator. this is my attempt but i get a broken arrow.
(2,038 Views)
Accepted by topic author jiji_830
  • There is no broken array, but your code is simply incomplete.
  • Since your three elements (index 4, 5, 6) are adjacent, you can use array subset to extract an array with these three elements.
  • Look for "sort array" in the array palette.
  • There is no need to maximize the front panel to the screen.
(1,993 Views)
thank you
(1,974 Views)
