Arrays i
I am still learning Arrays and I am running into a problem doing a factoring problem using an array
I am trying to figure out how to input a number in the array for example.
I want to put the number two in the second spot of the array.
(2,527 Views)
Your description is too ambiguous to help.
  • Where is the array? (e.g. in a shift register)
  • Where does the number come from?
  • Do you want to place it into a certain spot, moving the higher elements up (insert)?
  • Do you want to replace the current element  with the new value keeping the array the same size?
  • What is you program architecture?
As a first step, attach your actual VI and tell us exactly what the final output should be.
(2,518 Views)
Are you talking about programmatically?
Or as a user entering stuff in a front panel?
Your question sounds rather basic.  Like the kind of thing covered in the tutorials.
LabVIEW Introduction Course - Three Hours
Learn LabVIEW
(2,517 Views)
