Arrays part 2
So what I mean is the following: I have an array with the values 10,1,2,10,3,4. Now I want to delete one of the two 10's because I want to keep an array with all different values. How can I detect that I have two the same values in my array. That is the question. Can you maybe send me some example code for this issue. Thanks in advance, Davy
(2,900 Views)
And the answer is the same, use the Remove duplicates from array VI from the OpenG toolkit...
(2,900 Views)
