Article - LabVIEW 8.5 Feature - For Loop Conditional Terminal
[cross-post]
Hi All,
I've written an article about a new feature in LabVIEW 8.5 that I think is really useful.
-Jim
Message 1 of 15
(6,752 Views)
Excellent article Jim,
It's one of those features that I am starting to adopt, so it's good to be reminded of it.
Just one comment about the article.  You're missing the word "see" in the text below:
"In the screenshot below, you can the difference between the classic For Loop and one with a Conditional Terminal."
                                              ^see^
Message Edited by JoeLabView on 07-07-2008 11:59 AM
Message 2 of 15
(6,732 Views)
                                              ^see^
Hi JLV,
Thanks for the feedback and for your attention to detail!  Sometimes my brain gets ahead of my fingers 🙂
Yes, I really love this feature and have finally started to use it regularly.  Now that I am, I can't imagine life without it.
Cheers,
-Jim
Message 3 of 15
(6,727 Views)
I can. I'm still at 8.2. Smiley Very Happy
Message 4 of 15
(6,677 Views)
I have to switch between 8.5 and 8.2 and whenever I have to use 8.2, I'm disappointed when I can't find this feature 😞
Message 5 of 15
(6,672 Views)
Nice Article...reminds me of the nuggets you see on the forums.
I like the file delete example.  I had a flashback to when I first learned batch files in DOS. In the course of minutes I managed to rename every file in my C: drive:)  Luckily I had and image backup but very powerful stuff.
A hybrid conditional FOR loops...just another good reason for using auto indexing.
-SS
Message 6 of 15
(6,665 Views)
Thank you Jim for one more interesting article.
My humble suggestion would be to complete the article by adding an example that shows the differences between a
for loop with conditional terminal and a while loop (--> no need to extract the array size and to compare it with the loop index to stop after the last element of the array).
Message Edité par JB le 07-08-2008 08:47 AM
Message 7 of 15
(6,634 Views)
JB, you should note that this fails to account for the empty array case. To properly simulate the FLwB, you need to wrap the while loop in a case structure and only execute it if the array is not empty.
___________________
Try to take over the world!
Message 8 of 15
(6,624 Views)
I'm glad you found the article interesting 🙂
And, thanks for the suggestion -- there is certainly value in seeing the For Loop and While Loop implementations side-by-side, although they are not equivalent when the input array is empty (as using a While Loop to iterate over an ordered set gets complicated/ugly when we try to iterate over empty sets):
First, there is a bug in your upper loop: The decrement operation could cause the While Loop could execute infinitely, since the array length is zero and 0 -1 = -1 which is always less than (i.e., never equal) to i (which starts at 0 and increments on each iteration of the loop).  This is easily fixed by removing the decrement 😉
Second, the While Loop implementation would output a TRUE if the random number passed into the loop were 0, which is the default value of integers (the input array type).
For my article, what I really wanted to highlight is how a For Loop can behave more like a While Loop rather than the inverse.  For example, a For Loop is really a specialized While Loop that is optimized for iterating over ordered sets (iterating a pre-determined number of times is a For Loop's raison d'etre).  The Conditional Terminal allows one to conveniently break, should an exceptional condition occur while iterating over an ordered set.
Cheers,
-Jim
Message 9 of 15
(6,621 Views)
Good Article - I'm just starting to use these.
Just one comment:
The two for loops in Example 2 - searching an array -  will give different outputs if there is more than 1 match in the array. The first will give the index of the last matched element and the second will give the first matched element.
Dave
Message 10 of 15
(6,608 Views)
