As I can include a "IVA" in the Block Diagram.
Hello friends. I have a question about how to use the "IVAMATCHPATTERN ALGORITHM.vi" I located in my pc and is part of a library "LLB" but I can not carry it, I get a message that says it was compiled on an OS different. I am working with LV8.5.
Thank you.
Message 1 of 8
(3,938 Views)
What operating system are you using?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 8
(3,928 Views)
Hello, I'm using winXP sp2
Message 3 of 8
(3,920 Views)
Where does it reside?  Which llb?  Is it in vi.lib?  Many vi's in vi.lib are not intended for public use because they can change with each Labview version.
- tbob
Inventor of the WORM Global
Message 4 of 8
(3,917 Views)
The file is inside the library IVA MATCH PATTERN.LLB.
The specific file is IVA PATTERN MATCH ALGORITHM.vi which I can not load.
Message 5 of 8
(3,903 Views)
Hi Xontrol,
why don't you simply attach the llb or the vi here?
Message 6 of 8
(3,892 Views)
Attached the library as I find in my pc  54 IVA Match Pattern.llb
Message 7 of 8
(3,863 Views)
Hi Xontrol,
as the error message says: the files can't be loaded because their block diagram has been stripped.
You can load them only in LV8.2.1 - all newer version need to recompile the VIs, which is impossible due to missing block diagram...
Just reading that error message...
Message 8 of 8
(3,858 Views)
