Ask for help.!Error -536870902——DN4_ToErrorCluster_Polymorphic.vi
Please help me, thank you very much.
I get an error when I run Labview.
Error -536870902 occurred in
Possible Causes
The required property is not supported. When get DO->Scan Port->Port Count.
I am using Advantech's DAQ card 1753.
Thanks again, everyone.
(4,196 Views)
Hi Lil,
Possible Causes
When you are using a 3rd party hardware with its driver (VIs?) then you should read the manual for that 3rd party hardware and ask the support for that 3rd party hardware/software…
(4,168 Views)
Have you solvd this problem? I  have similar problems,and my card is  Advantech's PCI-1754. If you solved it, how did you do  it?
(3,265 Views)
@W.S_CHENG99 - as the error clearly states "The specified task is invalid" - please check why the task is invalid.
Santhosh
Soliton Technologies
(3,260 Views)
This issue is still unresolved.
Through Advantech's error code, it is found that the error code -536870902 is displayed as E000000A after transcoding. The corresponding content is: The required property is not supported.
 The required property is not supported. When set DI->Port Direction.
(3,041 Views)
