Ask for help: The compilation failed due to a Xilinx error.
Hellow,
The following error occurred when compiling a single CAN module. I failed to solve it after various attempts. I would be greatly grateful if someone could give some suggestions. Thanks in advance.
Hardware:
NI-cRIO-9042   +    NI 9853 (C series DAQ)
Software:
The host computer: Win 10 Pro (Version:1803), 64 bit.
 Labview 2018 (32 bit) , LabVIEW 2018 Real-Time Module, LabVIEW 2018 FPGA Module,
 NI CompactRIO Device Drivers 18.1
The list of installed software
The compiled VI by LabVIEW FPGA Cloud Compile Service
The compilation report
(3,796 Views)
Are you able to compile a shipping example for the same hardware?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(3,778 Views)
I have followed the instruction on the website to create a program as follows.
Unfortunately, the same error occurred. I wanted to find out where the error came from. Finally, I found it had also failed even only one module.
(3,774 Views)
As I can not find the Labview Realtime module for 64 bit operating system, I have to install 32 bit Labview. To check the problem, I have installed 32 bit Labview 2017 and other supporting software on another computer with 32 bit Win 7 operation system and  the same hardware. However, the same error occurred.
(3,770 Views)
Tedious, but try to search through the xilinx log for clues as to where the error is coming from. Start at the end of the log and work back.  Sometimes its missing clocks which are explicitly included in some IP cores.
(3,746 Views)
This is one of the shipping examples for the 9853:
C:\Program Files (x86)\National Instruments\LabVIEW 2017\examples\CompactRIO\Module Specific\NI 985x\cRIO CAN Basic\CAN Basic.lvproj
Open and try to compile it.
ALE Consultants
(3,724 Views)
I have found the solution. The CAN module need to be set to "Show Error Terminals".
(3,713 Views)
