Assign Filenames of Images
Here is my current VI...
Message 11 of 20
(2,200 Views)
It's error with WriteBMPFile cause you are deallocating (IMAQ Dispose) the Image inside the Aquisition Loop before save it.
Message 12 of 20
(2,183 Views)
How should I fix that?  I need to dispose of the images at some point right?
Message 13 of 20
(2,179 Views)
Accepted by topic author Max_2013
If there isn't before ... should be after, agree? 😄
Message 14 of 20
(2,176 Views)
Hmm, still not working.  Absolutely no files show up.
Message 15 of 20
(2,168 Views)
Sry, i had make one mistake. Image updated in previous post.
 Look  two attached examples. Both still working.
'm using IMAQdx Functions instead.
Message 16 of 20
(2,160 Views)
I really appreciate your help!
Something pretty frustrating has just happened.  I wired an error message to the save BMP portion and noticed that the BMP selection resulted in an "invalid image type" error.  Can I not save my image as a BMP?!  That seems rather odd.
So I decided to select PNG instead.  I actually named the file that I was saving as *.bmp, and checked my folder to see what happened.  It was a BMP image (hurray?), but I have a feeling that it is not a raw BMP.  Does selecting PNG and then writing .bmp compress the image and lose data or something?
And, any help regarding using write to file to actually save a BMP.
The rest of the code is working perfectly!
Thank you.
Message 17 of 20
(2,131 Views)
Functions: IMAQ ColorImageToArray, Flatten Pixmap and Write BMP File
Message 18 of 20
(2,116 Views)
Ok, so I just realized the a 24 bit is probably unecessary.  I am working with grayscale images from a 12bit camera.  The images go straight to 16 bit, but the read in BMP VI does not support 16-bit.  How can I work with the arrays of these 16 bit images, also how can I save them as 16bit in the first place?
The code I wrote to work with the arrays is for 24 bit images.  So if there is an easy way to get the image to 24 bits in the first place I guess I could do that.
Message 19 of 20
(2,103 Views)
I think should be better consider force a "typecast " with IMAQ CastImageType Function to U16 (If need) and use PNG format and write into file using IMAQ WriteFile2 Function. U can swap the extensions (Putting bmp instead png) in filepath (Works as the same)... consider this like a pseudo-workaround 😄
I found it inside Read BMP File Header.vi . Labview cannot handle 16 bits BMP. Even using Vision Toolkit (Always throws an error in Write BMP File)
Message 20 of 20
(2,078 Views)
