Assigning a name when using LVM Format
Hi
I am currently developing an application, which reads 9 Traces from an Agilent Spectrum Analyzer.
I am using the TDM File Format for a machine-readable format and the LVM Format (Write to Measurement File Express VI) for a human readable output  possibility. Now when I view the LVM format, I can find the lines:
---snip---
X0    0.0000000000000000E+0    0.0000000000000000E+0    0.0000000000000000E+0    0.0000000000000000E+0    0.0000000000000000E+0    0.0000000000000000E+0    0.0000000000000000E+0    0.0000000000000000E+0    0.0000000000000000E+0
Delta_X    2.493766E+7    2.493766E+7    2.493766E+7    2.493766E+7    2.493766E+7    2.493766E+7    2.493766E+7    2.493766E+7    2.493766E+7
***End_of_Header***
X_Value    Untitled    Untitled 1    Untitled 2    Untitled 3    Untitled 4    Untitled 5    Untitled 6    Untitled 7    Untitled 8    Comment
0.000000    -65.739000    -14.069000    -72.392000    -65.183000    -14.069000    -72.392000    -64.011000    -14.069000    -72.392000
2.493766E+7    -64.526000    -57.759000    -75.090000    -68.186000    -57.759000    -75.090000    -65.462000    -57.759000    -75.090000
---snip---
Now I would like to give the traces a name, instead of them being called Untitled. How would I do that?
(5,238 Views)
Hi Thomas
You can use Set Waveform Attribute where you can set Name string equal to NI_ChannelName which in turn is recognised by the Convert to DDT function.
Like this
David
Message Edited by David Crawford on 09-07-2006 10:07 AM
(5,233 Views)
Thank you, works perfectly - exactely what I've been looking for 🙂
(5,225 Views)
This is close but the number of channels being measure will end up changing and I would like a way to do this same thing but keep all the data in dynamic format so that minimal adjustments have to be made as the number of channels changes.
(5,178 Views)
(5,168 Views)
