Assigning values to combobox
Hello everyone
I am quite new to labview.......could someone please help me with combobox usage. My task is "When I select an item in combobox  it should read the data from an spreadsheet and disply it on the front panel. To the data of the spreadsheet I need to add few values manually and save it as a an new file". Could some some please expalin me in detail how could I do this. Thankyou in advance
Best Regards
Pratheek
Message 1 of 10
(4,207 Views)
Hi Pratheek,
here is a very similar thread, maybe you can team up with Bhargava
Message 2 of 10
(4,199 Views)
Hi
Thanks alot.  Could you please tell me how could I connect it to display the spreadsheet. The attached is how I am presently displaying the spreadsheet data and in the spreadsheet I am having the pin numbers  and I need to assign the pins definiton manually and again save it in a new spreadsheet file. Could you please tell me how could I do it
Regards
Pratheek
Message 3 of 10
(4,193 Views)
Hi GerdW
The VI from the previous thread is automatically updating the combobox..........But my problem is to open a spreadsheet file when I select an item in the combobox. Could you please tell me how can I do it
Regards
Pratheek
Message 4 of 10
(4,174 Views)
Hi Prahteek,
I think I suggested to use a ValueChange event for the combobox already in the other thread…
Message 5 of 10
(4,165 Views)
HI GerdW
I am sorry..... but i couldn't see anything related to value change event in the previous threads. I think i have to use value change event for assignig of pin definition when it displays the value of spreadsheet, but firstly how could I link items in dropdown list of combobox to the spreadsheet files ? Could you please help me.....
Regards
Pratheek
Message 6 of 10
(4,159 Views)
Accepted by topic author pratheek
Hi Pratheek,
Take a look at the attached vi. It may help you in going forward. I would strongly advice you to study the basics of Event structures and their usages. It is going to be handy if you are planning to make good  LV projects.
regards,
Nitzz
(Give Kudos To Good Answers, Mark it as a Solution If your Problem was Solved :smileywink:)
Message 7 of 10
(4,151 Views)
HI NitzZ
Thanks alot......you almost solved my problem Smiley Happy Could you suggest me where could I learn more on Event Structures and another my question is how could I save the changes made to the spreadsheet in a new file ?
Regards
Pratheek
Message 8 of 10
(4,146 Views)
Just to make my doubt a bit more clear, I am attaching the two snapshots below.....the 1st snapshot is the data from the spreadsheet and 2nd snapshot is of the assigned values to the pin numbers manually........could you please tell me how could I save these changes done to the spredsheet in a new .csv file
Regards
Pratheek
Message 9 of 10
(4,133 Views)
Hi Pratheek,
use WriteSpreadsheetFile to save that array to a CSV file…
Message 10 of 10
(4,129 Views)
