Assistance with Synchronizing IRIG Timecode Between V-data Generator and High-Speed Camera Using myDAQ and LabVIEW Body:
Hello NI Community,
I am working on a project where I need to synchronize a V-data IRIG-B Timecode Generator with a high-speed camera using an NI myDAQ device, and I’m controlling the setup with LabVIEW.
Objective: I aim to ensure that the IRIG timecode from the generator matches precisely with the timecode used by the high-speed camera, for accurate timestamping and synchronization of video frames.
Current Setup:
  • V-data IRIG-B Timecode Generator (Model: TCG) outputs an unmodulated IRIG-B signal.
  • High-speed camera with IRIG-B input for synchronization.
  • NI myDAQ device for data acquisition.
  • LabVIEW for data processing and control.
Challenges:
  • I am unsure of the best way to configure myDAQ to accurately capture the IRIG-B signal and how to compare this with the camera's internal IRIG implementation.
  • I need guidance on processing the IRIG signal in LabVIEW to match it with the high-speed camera's timecode.
Specific Questions:
  1. What are the best practices for setting up the myDAQ to read an unmodulated IRIG-B signal for maximum accuracy?
  2. How can I process the IRIG signal in LabVIEW so that it is in a format that can be compared with the camera's timecode?
  3. Are there any known issues or considerations when using myDAQ with IRIG timecodes and high-speed cameras that I should be aware of?
  4. Is there example LabVIEW code or VI that demonstrates handling and decoding IRIG-B signals?
Attempts So Far:
  • I have the myDAQ setup to read voltages, but I'm uncertain if I'm capturing the IRIG signal correctly.
  • I've tried thresholding the analog signal to create a digital representation but I'm not confident in the accuracy.
Any advice, example VIs, documentation, or tips you could provide would be greatly appreciated. Thank you in advance for your assistance!
- Joseph P.
Message 1 of 1
(1,682 Views)
