Associating requirements in my Word Document with NI Gateway
What do I need to do in order to associate requirements in my Word Document with NI Gateway? I have created a MS Word Style defined as Requirement_ID and Requirement_Text and applied them to their respective parts of the document but when I load the document in NI Gateway I get no response.
(3,503 Views)
Hello jstrong,
Please open the Microsoft Word Requirements Gateway example project located in the Requirements Gateway directory under <Requirements Gateway>\Examples\Word\Word Example.rqtf
You should be able to use this project along with the example word documents to get a better understanding of how to set up your own project.
Hope this helps!
Manooch H.
(3,490 Views)
Thanks for the info!  Can you tell me if the custom style should work in a Word table?
(3,470 Views)
jstrong -
You could customize the Word NIRG Type to add a new Requirement element which uses a regular expression to parse Table information.
When you include requirements in a Table, NIRG parses that information into the intermediate file in the form of |d Requirement_ID     REQX: blah, where "|" specifies the beginning of a new cell in the row and d specifies the cell number.
Please take a look at the attached project which is a modification of the NIRG Word example. You'll notice that I use a custome Type called Word1 to load the Word Example - Requirements.doc file.
Hope this helps!
Manooch H.
(3,451 Views)
