Asynchronous and timed message box
In a Windows and LV-64bits environment, what method do you use to display a dialog box that can be configured in asynchronous mode and with automatic closing after a certain delay?
Thank you in advance for any suggestions, and ideally, an example up to LV version 21.
Best regards
(2,479 Views)
I made a floating warning box like this.
I put an event handler in a VI and set the timeout case to whatever delay time that was needed (-1 for no timeout, etc.).  The event handler was overkill but I had some other things in mind.
I launched the VI using an asynchronous call and forget.  The launcher was wrapped in another VI to hide the details.
I use it to alert the user to non-critical errors that I do not want to interrupt execution of the calling VI.  The box pops up for a preset time, then closes automatically if not dismissed by the user.
(2,461 Views)
Thank you for these indications.
My preference would be a native Windows “MessageBox” but I haven't found one that offers these features. If anyone knows of a method that comes close, I'm very interested.
(2,405 Views)
I basically use a VI that is styled to look just like a Windows Dialog box.
=== Engineer Ambiguously ===
(2,403 Views)
Here is a possible workaround. This assumes that the message box has focus and the button you want pressed has key focus. The attached VI simulates a keyboard press, that is, the user pressing Return to dismiss the dialog. (This works if either the "Ok" or "Cancel" button has key focus. If it doesn't you can simulate a TAB press to move to the correct button.)
It would work as follows:
  1. Generate an occurrence.
  2. Set the Key Press VI with the occurrence, timeout, and key you want pressed.
  3. Run the dialog in parallel; if the user closes the dialog, fire the occurrence to exit the Key Press VI
(2,382 Views)
Does it autosize according to the length of the message or do you use an indicator with a vertical scrollbar ?
(2,328 Views)
TBH: I only use this in one place. In my qualification platform, it pops up when the user presses "Start" and gives the user one minute to select a different test step to start at or 1 (default), pressing "OK" will exit close this pop-up before the time out. That way the end user can restart a test that was aborted somewhere in the middle at the stage it was aborted. Our thermal chambers have a similar pop-up when you start a temperature profile, so I kinda used that as an example.
So to answer your question, the VI is sized to match the message, but it's always the same message.
BTW: It looks big because our test systems have a 19 inch touch screen, so everything I make has to have big buttons the technicians can press with their fat fingers.
(2,307 Views)
