Aternate languages in Labview
I have a machine which has an old dos based card. It works perfectly, it
just needs basic code to run. Would someone please explain what alternate
languages may be used as CIN's or reccomend how I can integrate the commands
I must send to the card into labview. I am just learning labview, but so
far all I see is that C is usable in labview. I do not see anything about
basic, fortran, pascal, etc. Any help/advice would be most appreciated. Thanks
very much
John
(2,983 Views)
In article <395cc48d@newsgroups.ni.com>,
"JMH" wrote:
> Hi,
it
alternate
commands
so
about
appreciated. Thanks
> very much
> John
Don't forget you can use Qbasic, in a DOs environment to control the
Serial port of your computer ( for input and ouput.).
Bertrand.
Sent via Deja.com http://www.deja.com/
Before you buy.
(2,983 Views)
