Attach Label to Shift Register
Is there an easy way to do this:
I can only do it with scripting.
Message 1 of 13
(5,235 Views)
Smells like a bug to me!
Work-around that works in 2015:
Drop the free-label INSIDE the loop and then attach to SR.
Drag Free-label ouside the loop.
Ben
Message 2 of 13
(5,198 Views)
I tried attaching the arrow through the BD and it worked for me.  I had to be VERY precise with selecting the shift register though.  VERY.
Bill
CLD
(Mid-Level minion.)
Message 3 of 13
(5,195 Views)
oops 2016.  lemme try again.  mine was 2015.
Bill
CLD
(Mid-Level minion.)
Message 4 of 13
(5,192 Views)
i can do it in 2016 as well
Bill
CLD
(Mid-Level minion.)
Message 5 of 13
(5,188 Views)
After reading you post, I tried again and you are correct that the "sweet spot" is very small, along the outside edge.
Robin Hood would be proud of you!
Ben
Message 6 of 13
(5,183 Views)
Really?  I can only attach it to the right side, not the left.
Message 7 of 13
(5,182 Views)
For me, attaching it from inside the loop is even tougher.  I think you have to attach it to the outside at the same small point as if you attached it from the outside.
It's tough because now you can't see the arrow head.
Bill
CLD
(Mid-Level minion.)
Message 8 of 13
(5,174 Views)
The tecnique is best described by one of my Better-half's lame jokes.
Q: How do you scare a unic ?
A: Unique up on him.
Yu have to catch the outside border of pixels. I use a track ball (not auto-tool select) so it may be easier for me.
Ben
Message 9 of 13
(5,171 Views)
Without even trying it, I bet the whole thing is manual selection of the tool.  I know it makes wiring a whole lot easier.
Bill
CLD
(Mid-Level minion.)
Message 10 of 13
(5,169 Views)
