Attach a TDM header to a streamed array of waveform arrays
I'd like to attach a tdm header to a file which contains an array of waveform arrays.  I've been learning about the tdm storage vi's but have had a hard time figuring out how to get the channels correct and the block allocation right.  I am using labview 7.1.  I have attached the vi I am using to generate the file.  It is quite messy but it should give you an idea of the file format.
Thanks.
Message 1 of 1
(2,402 Views)
