Attach folder in remote front panel
Hi, I need attach a folder with files created every day in a remote front panel. I've publicated the front panel with web publishing, but I want a download link of a folder.
How can I make it?
(3,239 Views)
Maybe writing code in HTML document created?
(3,217 Views)
There is no way to have your LabVIEW code create a link within a front panel that will send the web browser somewhere else. If the folder location never changes, then you can create a static link in the HTML document to that location. You could experiment with having your LabVIEW code re-write the file that is being served, but I don't know if that file is continuously read from disk or loaded only once at startup. You could also look into Embedded Server Pages Scripting.
(3,210 Views)
Ok, thanks! I'll try it,but I don't know if I can attach a folder in a HTML or just a file.
(3,194 Views)
