Attach two blocks
Hello
I am new to LabView, I would like to link this two blocks but I don't know how,  I am controlling a DC motor and I want to change the direction of rotation each time the counter detects pulses which 304 631 are issued by the motor encoder. I thought of a toggle but now I can not join them.
I leave the program for review
Thanks I hope your comments ....
(2,622 Views)
The problem is the dynamic data type (blue wire) caused by using all of those express VI's.
You need to convert the blue wire to a scalar data value using the From DDT express VI right before you compare it to the 304361.  Then the result of the comparison will be a boolean (rather than another blue DDT) which will then wire up nicely to the stop terminal.
(2,599 Views)
