Attaching a Cluster of 2 elements data type to dynamic data type wire.
Hey Folks,
How do I attach a cluster of 2 elements data type of wire with a Dynamic data type wire?
Or a Build XY Graph to a curve fitting2.
Thanks for the help.
Ty
(2,840 Views)
Hi Ty,
Try to use the "Express-VI Curve Fitting" which is at: Functions-> Signal Analysis -> Curve Fit.
You have to put this VI before the "Build XY Graph".
Otherwise, u can convert the siganls types by using the "Convert from Dynamic Data"
which is at : Functions-> Signal Mamipulation -> Convert from Dynamic Data.
Hope it Helps....
The Bush-Man
(2,828 Views)
