Attempt to Open or Create TDMS file gives error -2501
The TDMS file in "DEV.zip" does have some problems, it seems the data at the bottom in the file was mixed by some text.
Was the TDMS file generated by using the VI in " TDMS Problem.zip", when I running the VI, I could generate a TDMS file without any problem. In another word, I couldn't reproduce the problem in "DEV.zip".
Any thought?
Message 21 of 27
(1,908 Views)
Yes, it was generated using that VI. can the filename itself have have any impact? is there format or characters I can't use?
This is a small part of a much larger VI. The VI I sent you is 4th tier. The file path is  started on the main page, and then I add Test ID and unit serial number, and then I add the date to it. The file name changes at midnight based on the date, the rest stays the same. As I said before, this method has worked well for me over the last year using ASCII files (.csv)
The reason I bring this is because I changed the input to the VI I sent to a constant. The file name is Testing123.tdms, and it always works whether I stop it or not. If I use the other filename format mentioned previously it works until I stop and restart it.
My head is starting to hurt. For the life of me I cannot see what is wrong.
Message 22 of 27
(1,883 Views)
It looks like I'll need to contact NI directly to resolve this, but thanks to all who tried.
Message 23 of 27
(1,861 Views)
Definitely refer back to this thread and to YongqingYe (an NI empoyee), when you are in communications with NI.
Cheers
Message 24 of 27
(1,855 Views)
okay, so I can't contact NI directly because I don' t the service program membership. So, I'm stuck. Really Stuck
Any advice? I'm not going to be able to convince my management to upgrade just for this
Message 25 of 27
(1,837 Views)
Yeah, this is a tough one, since @YongqingYe can't reproduce your problem. I think the key is to try to reproduce the messed-up file from scratch to better isolate the problem. If we can't generate a file that is messed up using the VIs that you've provided then there's not much we can do to help.
Run through all of the code that made this file, put it in to one VI that runs through the same steps, and test whether the issue occurs again.
Cheers
Message 26 of 27
(1,832 Views)
Hi Speaks,
I run the VI you attached and try to reproduce the problem. I put your VI in a while loop and run it for the entire afternoon for hundreds of thousands of times, but unfortunately, I still couldn't reproduce.
I would suggest you use the same way to try to reproduce and let me know whether it can be reproduced or not.
And another way is, try to remove the csv file related code firstly and try to see whether the problem exists or not. And if it still doesn't work, try to remove small part TDMS related code in your big project and remove more and more, and see whether the problem exists or not and narrow down to where the problem is.
Message 27 of 27
(1,770 Views)
