Attempting to get a pre-developed VI to run
I am attempting to get a pre-developed VI up and running.  The developer of the VI has given access to the VI via the source code, yet when installing the VI I keep running into a few errors that seem to be more system based, and was looking for some help on getting them straightened out.
The errors that I get when first running the Main VI and downloading the other Sub-VIs within the main VI are the following:
Utility-Graph File I-O.vi:  "The File Dialog Function no longer supports the datalog type input"
Keyfile I-O.vi:  "The File Dialog Function no longer supports the datalog type input"
When I go to run the Main VI it won't take the backdoor keycode installed for the Main VI's encrypted activation, and gives the message:
(1) Missing or corrupt file:  C:\Documents and Settings\jon\Desktop\Labview\Config\keyfile.dlg
(2) Missing or corrupt configuration:  C:\Documents and Settings\jon\Desktop\Labview\"Main VI's name.ini"
I went ahead and stripped the Encryption Activation program from the Main VI, and still the (1) & (2) messages appeared.
Any suggestions?
Thanks.
(2,947 Views)
What LV version was the VI originally developed in and what version are you using now?
Look at this thread How Do I Convert LV7.1 Datalog Files to LV8 Format?
Something about datalog files changed LV versions.  Maybe the info in here is related to your issue.
(2,921 Views)
thanks Raven... I'll give it a shot in re-developing some of the datalog files from 7.1.
though still stumped here on why the .ini file isn't already built into the pre-existing main VI that calls all of the sub-vis.
(2,881 Views)
