Attribute Value to Multiples Menus Rings
I have a VI with many Menu Rings and I have to make all then show the value in the position 0. Is there a way to do that in all of then at the same time, without making a Propriety Node for every Menu Ring?
Thanks for the Help,
Marcus
(2,525 Views)
Accepted by topic author MarcusBianchi
You could make an array of references and send that to a subvi that has a for loop inside. Have one control that sets off of the references. This way you have everything bundled up in one subvi verses all of the controls.
Tim
GHSP
(2,516 Views)
