Audio Input
Hello everyone,
I'm working on a school subject and actually what I have to do is (look example). First of all I need to transfer music with a cable from my phone to labview, I want to select a music file and when I press play, the song will play but it will also transfer into Hz, so actually kinda a speaker with leds, and when the bass becomes higher. The leds go higher and when the leds are low, the leds go lower.
Example: https://www.youtube.com/watch?v=cU_mXKno5Ak
Message 1 of 15
(6,724 Views)
You will need to break your project down into smaller tasks.
1.  How to get music from your phone to your computer into LabVIEW.
2.  How to play the song.
3.  How to display it as an equalizer.  (probably need to do an FFT)
4.  How modify the frequency before you play it.
The trickiest part will be #1.  Do you know how to get the music off your phone?
Message 2 of 15
(6,705 Views)
My teacher told me this:
Receive music analogue (via a sound cable) from for example, your Mobile Phone in LabVIEW. This will then have to be done via the sound card.
#1.  Do you know how to get the music off your phone: Euhm i thought with a aux cable?
5. I also need to use a "power spectrum", don't really know how this works.
Message 3 of 15
(6,698 Views)
Accepted by topic author Brxwnii
That is an important detail to add in this message that gives some actual direction.  When I read your first message, I was thinking you were going to use the USB cable to connect the phone to the PC.
Yes, use a stereo cable between your phone's headphone jack and the auxiliary input of your sound card.  Look in LabVIEW's Example Finder for examples on how to acquire sounds from the sound card.  Look in the Graphics & Sound palette on the block diagram.
A power spectrum is an FFT.  Fast Fourier Transform.  Search LabVIEW help for that.  Look in the Signal Processing palette.
Message 4 of 15
(6,679 Views)
Could you help me via Discord? Please 🙏🏽 Send me
Message 5 of 15
(6,671 Views)
If your phone actually has a headphone jack (many don't these days) or you have an adapter cable then you should be able to plug right in to your PC sound card.  Headphones signals are amplified so I would try the Line In rather than the Microphone input if you have a choice (my HP work PC has only Mic In).
Then open the sound settings and hopefully you will have some kind of "Test Microphone" or even a sound mixer to see if you are connected right.
Once you're sure you have the input into your sound card open the LabVIEW example called Continuous Sound Input (use the defaults) and you should have a waveform display.
The same signal that goes to the graph can be plugged into the Waveform Measurements VIs (assuming they're in your student version) so start playing around!
As RavensFan mentioned an FFT will be interesting and the Extract Tones VIs might be useful for you as well.
One hint:  Set the sound format option to 1 channel and avoid dealing with stereo signals until you get the basics down.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 6 of 15
(6,659 Views)
What does that mean?
Message 7 of 15
(6,637 Views)
Discord is an instant messaging and VOIP app sort of like skype but for groups.
Message 8 of 15
(6,622 Views)
Never heard of it.  No reason to ever need to use it.
" ... like skype but for groups"?   Skype does group messaging as well.
Message 9 of 15
(6,606 Views)
Assignment is due tomorrow. Smiley Wink
mcduff
Message 10 of 15
(6,591 Views)
