Audio Playback
Hi everyone, I'm wondering how to implement audio playback in the following codes. Basically, the goal is to have a control which can playback the audio. Some posts suggest that windows media player can be used, but that it will make the front panel looks messy. Can anyone give a help on how to achieve this? The import file is wav file. Thanks!
(3,669 Views)
I'm assuming you didn't write the VI you showed.  What is your question?  What about that VI is deficient, in your opinion?  How do you want to modify it?  What have you tried to do?
BS
(3,653 Views)
The goal is to make the video have the playback feature. This is the same as the playback of a video, when you move the scroll back and forth. So far, the only way I know is to implement a windows media player.
(3,636 Views)
