Audio/boolean feeback to go off at defined intervals?
Dear LabView community,
I have set up a moving average (5 peaks)on data being streamed in. I have created audio/boolean threshold loops, which set off each time the moving average changes. However, i want to set up the feedbac to possibly go off on either every 5th average change or every 5 second cycle. I there a way to do this? Also how can i alter the duration of activated boolean?
Thanks people,
Ad
(2,525 Views)
Will any of these meet your needs?  Not sure what you mean by altering duration of a boolean.
--Using LV8.2, 8.6, 2009, 2012--
(2,500 Views)
Thanks Taper, i will try them on Monday.
I want the activated boolean to stay on for longer, as it goes on and off very quickly.
(2,480 Views)
Hi Taper,
The cannot seem to implement the threshold sounds/booleans every 5th change. Would it be possible for you to alter the code for me and display it as a png for me to follow? I am currently a student with limited knowledge on labview.
Thank your so much for your help and support, its greatly appreciated.
Ad
(2,457 Views)
