Audio streaming
the idea used in cycle.vi is to find a non-negative value of the sine wave searching from a negative value. This is token as staring. And take the rest of the waveform until the last negative value of the waveform when the waveform is back tracked from a positive value. Basicly, the pupurse is to take a complete cycle for loopback.
But it has clip sound.
Any one can help?
Thank you.
Message 11 of 12
(1,236 Views)
it seems like that the cycle.vi is OK. the problem is from the way i notify the loopback..
I use queue time out. this may not work.
Message 12 of 12
(1,223 Views)
