Audiometer Balance Help
Good day,
I am making an audiometer as a final project for the University, I have it done (I guess) however I need to make a switch for right and left channels, also that switch must use different graphs on the same plot, I hope someone could tell me how this is done, I have done my research but I have no Idea so far. Please find the attached VI.
Best regards.
(3,077 Views)
@AlexNelly wrote:
Good day,
Best regards.
We really need more information to help.... 8 Months on this project?
OK, where do you think you generate Left or Right chanels?
STOP hiding objects under objects (Where did you hide the OR and conditional terminal on the first While loop?)
Why two shift registers for the dbl arrays?  (and you might just be hitting a known issue there but, since the arrays are the same you don't see it)
So what is Left?  What is Right? and how do you wish to scale them?
(3,056 Views)
