Authentication to Web Services by U2F
I am implementing a medical device trial using Web Services as the back end server. The client is written in Python and executes on a Raspberry Pi. It sends data to the server, gets an answer, and administers a drug to a patient based on the answer. This needs to be done in the presence of a coinvestigator, who will have specialized skills to assure patient safety and data integrity. I'd really like to assure that only coinvestigators can use the client, so second factor identification would seem mandatory. There are some inexpensive devices, such as the FIDO U2F Security Key, that seem to fit the bill. I already know how to use the Web Services API Key, but this seems significantly less secure than U2F, as the secretID is embedded in the code. What would be really nice would be a way to use U2F as an alternate authentication scheme for Web Services. Ideally, baked in by NI.
Thoughts?
(4,310 Views)
I believe you want to use a 2-Factor for Authorization to a Web Service / REST API that uses OAuth and/or Client Secrets. FIDO U2F and FIDO UAF are specifically designed for Authentication. They do not address the API Authorization piece.
(4,265 Views)
I'm open to suggestions. My only requirement is that only someone who has the hardware key can access the server. Apologies for poor choice of jargon; "I'm a doctor, Jim, not an English professor!"
(4,258 Views)
I haven't seen any Web Service / REST API that implements 2-Factor for API authorization. Not to say that it is not possible, but something like this would be very customized and the client app would have to properly designed with proper security controls.
(4,244 Views)
Hi jemandel,
 I am not very sure what you mean. I do not understand very well if you want to change your Python program to a LabVIEW program that uses Web Services or if you are looking into hardware that can work for this application.
LabVIEW have features that can help you. You might be able to find information on the following links:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LgPSAU&l=en-US
https://www.ni.com/docs/en-US/bundle/labview/page/configure-web-services-security-view.html
https://www.ni.com/docs/en-US/bundle/labview/page/tutorial-creating-and-publishing-a-labview-web-ser...
If you require hardware, my recommendation is to look into www.ni.com/products.
Please let me know if I misunderstood your question.
Luis C.
(4,172 Views)
