Auto Index Tunnel and reading array one by one
I am trying read values one at a time(to simulate dac acquisition) from a 2 coloumn excel(tab de limited) sheet and plot on an xy graph.
I have posted the VI  I’m working with. To get the values one at time I have used a for loop and used an auto index tunnel.however I’m getting only one set values (the ones wired to y…please see the diagram). The other(supposed to be x values)appear to be always zero…..hence no graph is plotted. What can I do so I get both the values?
On searching the forum I found the following block diagram and I’m assuming it works…. But I can’t figure what the array used here is. Can some one tell me?
I have figured out that perhaps the error occurs after the auto index tunnel because on taking a indicator from the wire after auto index tunnel a 1d array is displayed(see block diag) while before it I get a 2d array.i tried changing the conver to dynamic to 2d but that didn't work. But in the above diagram it doesn’t seem to be a problem as the person has taken both x and y outputs of the array. (I am assuming this is a block diagram which works).tell me how to go about this.
Pls help
DiPS
(4,789 Views)
If you autoindex a 2D array, you get one row at each iteration. A row is a 1D array, right?
Seems to work just fine. See attached.
(4,780 Views)
hey,
thanx a lot... now it works
by the way.. is there any way i can make the x-axis in current system time. i tried making it absolute and relative in the graph props but that doesnt help... usually when i simulate a signals it works fine(ie current sys time is displayed o graphs) probably because i choose absolute time stamp in sim signal props.
in this case however i'm reading from a sprdsht and plotting on a graph.. so wat do i do to make x axis current sys time..
thanx
DiPS
(4,750 Views)
