Auto Rotating String Indicator
Hi all,
I'd like to create an auto rotating string indicator such as the LV News indicator you see when you open LV.
See below image:
(5,572 Views)
You mean scrolling? You could write the string to the indicator and change the scroll point with a property node.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,551 Views)
You could also draw the text into a 2D picture control, that would let you explicitly control the text position to a pixel.
Mike...
LabVIEW Champion
(5,546 Views)
I think Mike is talking about something like the image below. I loaded a string indicator with separate lines of text, made it transparent then sandwiched the indicator between two "flat box" decorations. Then I used a position proerty node to move the indicator up. Goes to show, you can do just about anything in LabVIEW. Some solutions are just more complicated than others.
CLD
(5,524 Views)
You can do a lot in LV.
I'm looking for a robust solution I can simply feed an array of strings into.
I guess it's like a neon sign which can rotate text within a confined area and I'm surprised controls indicators like this aren't built into LV.
(5,516 Views)
You could also use an array of boolean LEDs and make a scoreboard.  😉
Bill
CLD
(Mid-Level minion.)
(5,486 Views)
Why are you surprised? This isn't exactly standard behavior, so why should NI spend time on creating something like this, particularly when doing it yourself is really easy?
If memory serves, the method of changing the indicator position, already suggested in this thread, is the one actually used by the RSS ticker (although I would probably put it in a cluster rather than between decorations, but that's an implementation detail). If you want it in more than one location or to be really easy to use, you could use an XControl, but be aware that this will require running a parallel process which will handle the motion.
___________________
Try to take over the world!
(5,453 Views)
