Auto exposure in Imagining Source Camera DMK Series
Here, I have attached the VI in which I want to do auto exposure and set that exposure value.
Basically this is program for laser beam analysis on live image.
Basically I want to set exposure time accordingly laser beam intensity.
If anyone previously worked on it then please help me with that. I am new to image processing.
(4,126 Views)
You should be able to modify attributes of your camera using IMAQ functions. Idk what the attributes will look like for your specific camera, but here is a forum post that talks about how they did this with a SmartCamera:
https://forums.ni.com/t5/LabVIEW/Labview-Program-to-adjust-the-exposure-time-of-the-smart-camera/td-...
(4,093 Views)
I can. My question was if I have a value of max intensity of the image and then accordingly that if I want to adjust my exposure time with help of for loop or while loop. that thing I don't know how to implement?
(4,080 Views)
If you know how to edit your configuration file, then technically you could make a State Machine that has different parameters to set within each state based on the intensity value you have.
Tutorial: State Machines
https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat...
(4,071 Views)
