11-13-2014 02:56 PM
I guess it doesn't really matter how many times you transpose a 2D array to get the expected result. Personally I'm partial to 0 or 1 but its a really cheap operation.
11-17-2014 11:11 AM
I added a new column to the data file: timestamp. Is there a way I can get data from the Excel based on a range that I input? In my file, the first timestamp is 12:15:42.406 and the last one is 12:15:44.282. How can I enter a range e.g. 12:15:42.406 - 12:15:43.544 and only display that data? Could someone point me in the right direction?
Also, how can I choose an answer as the solution?
Thanks.
11-17-2014 11:27 AM
If you have the two timestamps you want to be between and an array of the timestamps, use Threashold 1D Array to find the index range that you should be using.
11-17-2014 05:39 PM
Time to XL can be downloaded from here https://decibel.ni.com/content/docs/DOC-19689
Excel won't treat strings as dates
11-18-2014 12:51 PM
Is it possible to simply click on the time during run-time and change it?
Also, how can I reduce the range? The time axis currently has a range of 17 seconds. I'm not sure where that number is coming form. I tried going to properties and changing the scaling factors but I can't change it.
11-18-2014 01:35 PM
11-18-2014 01:54 PM
If I change the chart history length, doesn't it affect what's stored in the chart data buffer?
11-18-2014 03:53 PM - edited 11-18-2014 03:56 PM
Yes, of course! Isn't that the point?
I don't know what you tried when you say that "... I tried going to properties and changing the scaling factors but I can't change it....".
You need to define dt so the chart knows the time increment per point. You can change the visible range by turning off autoscaling and defining the axis end points.
11-19-2014 10:59 AM - edited 11-19-2014 11:01 AM
So just to clarify, the chart data buffer is where data is stored, right? Let's say I change it to 100 points instead of 1024; does that mean only 100 points will be saved in the buffer at any given time?
Also, I tried what you said. I turned off autoscale and tried to define the axis end points (minimum and maxium on the scales tab in chart properties) but I can't save the changes I make. When I clicked ok and went back to properties, it has automatically changed back to what it was before. Please see the attached file. For the first graph, the difference isn't even one second which is too small but for the second one, it's almost 17 seconds which is too big. That's what I'm trying to fix.
11-19-2014 11:13 AM - edited 11-19-2014 11:16 AM
Never ever attach a modified VI with the same name as the original VI. This makes debugging difficult. Always create a new unique name.
A chart keeps a buffer of the given size. These are points per plot, so if a chart has 4 plots, each keeps 100 points if the history lenght is 100. If new data arrives and the buffer is full, the oldest data gets discarded.
