Auto-resetting boolean after 5 seconds?
Hey,
At first sorry for my bad English, I'm Dutch
I have a case-structure and I want it to be 'true' for 5 seconds (after I push the boolean) and then be false again.
I fixed that with an extra case-structure wich contains an  'Elapsed time' that returns 'false' after 5 seconds.
But... I want to be able to do that several times while the VI's runs. Right now I can only do it once because the 'Elapsed time' doesnt go back to zero after it returns "false".
ANY suggestions are very welcome 🙂
ps I put my VI in the attachement
Cheers
(4,281 Views)
Try setting the "Auto-Reset" input of the Elapsed Time function to TRUE.  This will reset the timer each time it hits its time target.
Dan
(4,270 Views)
Thanks for your reply, I allready tried that but then the true false case that contains the 'elapsed time' stays true (it just keeps running)
(4,243 Views)
Hi chickensoup,
Check this code.I have disabled some code in your block diagram. Have changed mechanical action of Boolean control.
Is this what you want?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,237 Views)
Thanks for your help, but unfortunately this is not what I need. For now i made a compromise and use 2 buttons
(4,199 Views)
