AutoScale don't work correctly with the FP closed
In order to print a graph, I've created a sub-vi which prints on completion. I'm using an attribute nodo to autoscale the graph, but I've seen the graph does not update when de Front Panel is closed. If I open the panel and run it again then works correctly. What can I do to get the automatic autoscale
(2,720 Views)
What version of LabVIEW are you using? I think there was a similar issue with LabVIEW 4.0 but it's been fixed since then.
J.R. Allen
(2,720 Views)
I'm using LabView 6.0i
(2,720 Views)
