Autoadjusting scales of gauges in modern pallete
Is it possible to change the units e.g mm to inch and have the scales of gauges change automatically to the maximum and minimum values defined for the gauges?
Kind Regards
Austin
(2,792 Views)
Hi Austin,
Yes, it is possible to automatically change the units you want the graph to be displayed in.We can do this using property nodes and case structures. I have produced a quick example to show you how this can be done. The example simply allows you to change units between meters and centimeters.
I hope this helps, but please do let me know if you need anymore help.
Many Thanks,
Aaron. E
Product Performance Engineer
Dyson
(2,775 Views)
Hello Aaron,
Can you save this for version 2010 please. I dont have 2011
(2,771 Views)
Hi Austin,
Please find attached the code for LabVIEW 2010.
Many Thanks,
Aaron. E
Dyson
(2,768 Views)
Sorry please find the attached using moden controls.
Many Thanks,
Aaron. E
Dyson
(2,764 Views)
