Autofocus algorithm example
Hi all,
I have searched the forums a number of different ways and have gotten a ton of hits saying to search through the forum for examples but I haven't been able to find a good example of an autofocusing algorithm. I am looking at doing something similar to this, with a linear stage but I do not have the IMAQ module. I plan on building off of the convolution.vi example offered in the LabVIEW examples. I understand the concepts but I am looking for a starting off point for a somewhat efficient programming algorithm I can build off of as I'm not really sure the quickest method for focusing.
I know this will need some customization for timing, slide movement, and image acquisition but thought the forums might give me some additional ideas and a starting off point.
Jeremy
(7,967 Views)
Hi Jeremy,
The quickest and easist way to autofocus has more to do with your comfort on the topic. I am not an expert by any means but I would take a look here
Joe Daily
may the G be with you ....
(7,932 Views)
